Problem with my '92 3.9L
Old May 23, 2011 | 03:07 PM
McFly360's Avatar
McFly360
Default Problem with my '92 3.9L
i am having trouble with my 3.9L. It cranks and starts fine but when i run the rpms up 2200 the engine starts miss firing and and stalls. at first i thought it was and ignition problem so i checked cap and rotor which was worn but not damaged but i replaced anyway being as they are cheap parts. next i checked the spark plug wires with my ohm meter and they passed the spec alldata gave me. next i started checking sensor inputs with a lab scope and the only thing i could find was a little bit of "trash" or interference on my distributor position sensor output to my pcm. so i replaced it and still no luck. i also have double checked my firing order and it is correct. next im thinking i should replace the ignition coil as im starting to run out of options and ideas. does anyone have any ideas on what could be causing this????
Old May 23, 2011 | 03:24 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The distributer could have moved. Put #1 cly TDC and make sure the rotor is pointing directly to #1 on the cap.
Old May 23, 2011 | 05:15 PM
McFly360's Avatar
McFly360
just checked and when i put cylinder #1 to TDC of intake stroke the rotor was pointing directely to number #1 on the cap. so thats not it...
Old May 24, 2011 | 11:12 AM
misfitdakota_95's Avatar
misfitdakota_95
check your fuel pressure, make sure it's not dropping down. The spec should be 39 psi +/- 5 psi.
