93 4X4 3.9 headlights not workin AGAIN!
Subscribe
May 24, 2011 | 12:56 AM
When I got my p/u in Jan, my headlights would quit then work again, and I replaced the switch. Now they quit (burning plastic smell) and I had to drive home by pulling the turn signal lever back for headlights!! Do these trucks eat headlight switches?
Reply 0
May 24, 2011 | 11:05 AM
If it's burning the plastic housing, you have a serious problem. Check for any exposed wires that might be touching metal, thus causing a short to ground. Pull up a wiring diagram for the headlights and check for a blown fuse. Also, do you have aftermarket fog lights/runnings lights, etc. installed on your truck?
Reply 0
May 24, 2011 | 01:04 PM
did you put in an aftermarket switch?
if so they are JUNK!!!.
just return it go to the dealer and get a good one. i put in 4 am switches and finally orderd myne and replaced it with a mopar switch. been good for 6 months now.
Reply 0
Subscribe
