Electric fans w/ custom shroud
Old May 25, 2011 | 04:56 AM
Z Guy's Avatar
Z Guy
Default Electric fans w/ custom shroud
pulled the factory fan off at the beginning of winter when i lifted it (there is a thread on it); now that it's getting hot out need to put my electric fans on. I do a good amount of hauling so a shroud is a must. As you may have noticed there isn't a ton of room on the V8s so it gets a little interesting.
picked up some slim Taurus fans a while back. started with a sheet of aluminum that i cut and since i don't have any cool tools like a brake most work was done with a vice, torch and hammer.
now that i've done this from scratch once i could do it again much better and faster. i made a lot of mistakes and took way longer than needed..
here is me starting out
making sure it fit.
cutting holes
used caulking as sealant... don't think i'd do that again. at least not the same way (use a heat gun to cure faster. i don't care how much more fun a torch is)
tried red paint first
black did a better job of covering up my mistakes...
red fans in the front, but black fans in the back
here is the photobucket with all my pictures
http://s1209.photobucket.com/albums/...cpZZ1QQtppZZ16
Old May 25, 2011 | 11:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool! It will work just fine.
I'll add to the FAQ2 for others.
Old May 25, 2011 | 05:49 PM
Sauxon's Avatar
Sauxon
I like that idea, maybe something I can try to fab up
My fans were supposed to arrive today actually
What did you use for your thermostat/switch?
Old May 26, 2011 | 01:46 AM
Z Guy's Avatar
Z Guy
i picked up a fan control unit from O'reily auto parts that included the thermostat sensor and everything.
Old May 26, 2011 | 06:59 PM
Sauxon's Avatar
Sauxon
Where did you place the thermostat? Or did you just get the probe one?
