Performance Chips
Old Jun 3, 2011 | 06:34 PM
ddgdkt96's Avatar
ddgdkt96
Default Performance Chips
Hey, whats this I hear about a performance chip that gives you better gas mileage and more power? the Jet ones are junk? are there any other ones that we can use?
thanks
P
Old Jun 3, 2011 | 10:27 PM
g. man's Avatar
g. man
I have a stage two Jet power control module on my '93 3.9 and I like it. Gained two mpg, and it makes a noticeable difference in power. Part #99302-S. It's easy to find on their website, but it's 330 bucks. I'm not sure if you can use it with stock exhaust. I don't like how they plug in either. The bolt on the trucks wire harness is not long enough to be used once the chip is on it. But it seems to hold just fine. Some one on here said it burn up their connector, but I've really liked mine. It's almost not the same truck with out it. Just my opinion, hope this helps.
Old Jun 4, 2011 | 01:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The Jet Stage II module burnt up my PCM connector. Several others had the same problem too.
The only direct fit option is Mopar High Performance Computers. For the V8's they still make them. But for the V6 they are discontinued. There still are a few around. Try www.google.com or www.ebay.com or www.craigslist.org
The V6 MP PCM part number is in the FAQ2, Google the part number.
There are a few other options. This list is in the FAQ2, as well as TONS of other performance tips.
Performance Computer Upgrades
________________________________________
Engine Stand Alone Engine Management Systems
http://www.fuelairspark.com/Products...er/sb/over.asp
Factory Computer Reflashes
There are very little for Dodge OBD1.
The best would be a Mopar performance computer. You can get them at http://www.mopar.com/performance/index.html or http://www.summitracing.com/
Jet chips has a plug in. It has been cheep quality and not worth it for most. http://www.jetchip.com/
You can get http://www.hypertech.com/Products/Po...uning%20Module (No reviews yet)
Here is one that flashes and can give you a handheld unit. http://www.bgperformancepcm.com/#magnum
At once this site had it listed but the site seems to be down now. http://nrar.com/
You can Also get get a multi-processor-driven signal manipulator that goes in-line between your engine and ECU.
http://www.unichip.us/dodge.asp
Petersen's 4Wheel & Off-Road Magazine did an article on it.
http://www.4wheeloffroad.com/techart...ing/index.html
Old Jun 6, 2011 | 01:41 AM
ddgdkt96's Avatar
ddgdkt96
Thank you for your help, I will have to look and see if this is what I want to do.
Peace
