suspension lift? plz help anyone
Old Jun 20, 2011 | 09:15 PM
dakotalover42's Avatar
dakotalover42
Default suspension lift? plz help anyone
i have a 1993 dodge dakota sport 4x4 an i cant find a suspension lift any where i can get lift blocks an shocks but i that doesnt help with the front anyone know anywhere where i can get a suspension lift? or how to lift the front also?
plz help ive been looking everywhere literally?!?!?!?!?!?
Old Jun 20, 2011 | 11:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Maybe not everywhere. A few posts above this one is the FAQ2. With TONS of lift ideas and links to lift parts/kits.
https://dodgeforum.com/forum/1st-gen...-and-more.html
Lifting
________________________________________
4wd
Leveling kit: From factory the rear of the truck is higher then the front, so when you put a load in it, it won't sag. A leveling kit lifts up only the front of the truck to make it level with the rear. If you want to make it level just crank up the torsion bars.
Lift kit: A lift kit lifts the front and back of the truck.
Body kit 2in. http://www.summitracing.com/parts/PRA-PA-642/
https://dodgeforum.com/forum/1st-gen-...t-install.html
Custom 6in body kit. https://dodgeforum.com/forum/1st-gen-...y-tires-d.html
Full suspension kit 4in. ($1,700) http://www.streetperformance.com/par...9-dd43ssv.html
The kit is no loner made, if you look up the kit on Google by part number lots of sites list it. Call up the places to verify.
This link is just for reference on the part numbers. Click HERE. Here is a great site about installing the kit. http://www.walt-n-ingrid.com/modifications.html
Here is one site with pictures of the kit installed. Click HERE
Lift keys 2 inch. Lots listed on http://www.ebay.com/ 97-up may work!
http://www.totalperformanceonline.co...1321/50/100-14
Or you can just crank your torsion bars and add rear blocks for 1 inch or so. Here is a How to. https://dodgeforum.com/forum/1979009-post2.html
You can tack weld some 1/4 inch steal strips to your keys. Here is a post on it. 1st-gen-dakota/175855-cheep-lift-post1417241.html#post1417241
You can get blocks just about any parts stores. Sizes are available from 1 inch - 6 inches.
You can get Shorter rear spring shackles.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...with-pics.html
https://dodgeforum.com/forum/1st-gen-...ut-blocks.html
https://dodgeforum.com/forum/1st-gen-...le-hanger.html
If you got a V6 you can get V8 torsion bars to give you an extra inch or so.
Add a leaf too.
http://www.jcwhitney.com
You can get air shocks too. These are not air bags. So you don't need an on-board compressor. http://shop.oreillyauto.com/productd...ype=50&PTSet=A
Or
https://www.shockshopusa.com/thankyou.html
Universal air bags. http://www.airbagit.com/Default.asp?Redirected=Y
http://www.summitracing.com/parts/AIR-59501/
http://www.streetbeatcustoms.com/
You can get coil over rear shocks. It may add an inch of height. http://shop.oreillyauto.com/productd...ype=50&PTSet=A
Old Jun 21, 2011 | 11:45 AM
dakotalover42
k thanks i just purchased a 2 inch body lift 3inch lift blocks an 3 inch torsion keys but im still on the hunt for shocks that will fit it.. any ideas of where i can find them?
Old Jun 21, 2011 | 06:56 PM
festerw's Avatar
festerw
Monroe has a catalog online that has listings for extended shocks.
