Brakelines
Now, as for single-piece versus multiple-piece: I prefer a single-piece installation myself. It's more reliable. However, there's nothing saying you can't use several pieces of pre-made line spliced together - it's just that each joint is a potential leak.
You will need a tubing cutter and flaring tool to install a single-piece line.
Those tools will probably not be necessary to hook together pre-made lengths.
i was looking on Jegs website and they have a Teflon coated brake line for pretty cheap and then they have fitting have any of you guys used this stuff and is it good or bad http://www.jegs.com/p/JEGS-Performan...00664/10002/-1
Let's start fresh. What exactly are you replacing on the truck? Are you replacing the steel brake lines? Or are you replacing the rubber brake hoses at the calipers and rear axle?
Okay, that's what I thought originally.
You should replace that with steel line. Rubber or synthetic hoses in a hydraulic system are usually only acceptable if/where movement is needed, and even then, you should keep the length as short as possible, and of course the hose needs to be built to handle hydraulic pressure with a minimum of expansion.
Update: OK first i got a 25' coil of steel brake line to make my line with and in the the process broke 3 rental flare kits the first one one of the bar bolts broke so got my deposit back and went to another parts store and rented another one then the nipple adapter thing broke so i exchanged it for another one same thing happened so i gave up and bought a pre made piece of line best invention ever worked great so now im at the point were i need to bleed it and hope for no leaks . now the guy at O'Reillys said let gravity do its job and dont pump the pedal is this a good method
