new spindle?
Old Jul 20, 2011 | 06:52 PM
4x4Dakota93's Avatar
4x4Dakota93
Default new spindle?
Is there no longer a place to purchase new spindles? its for a 93 Dakota 4x4 with 3.9, I called dealership, they no longer carry them, no where online but junkyards can I find them and they look like rust buckets
Old Jul 21, 2011 | 02:07 AM
Crazy4x4RT's Avatar
Crazy4x4RT
4wd doesn't have spindles. Are talking about the Hub bearings? If so all autopart stores sell them.
Old Jul 21, 2011 | 05:50 AM
4x4Dakota93
Yes! Ok another name front knuckle, the piece that the hub assy goes on and the calipers mounts to, I stripped out one of calipers holes and tryed to retap and failed, uneven wear now, where can I find the knuckle? If that's what its called
Old Jul 21, 2011 | 11:40 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Okay a knuckle is different from a spindle, but some knuckles has spindles on it, but not all. But if all you did is strip out the threads you have a few choices. (Details in the first post is good)
Buy over size threaded pins, most auto-parts stores sell them specific to our trucks.
Just use a Heli-coil cheep and easy to do. Drill, tap and insert the Heli-coils which reduce the new larger thread to the correct size. http://www.emhart.com/brands/heli-coil/ Most auto-parts stores sell them.
Old Jul 21, 2011 | 02:54 PM
4x4Dakota93
Well I'm not sure if I did the helicoil correctly or not? I did this awhile back and I've noticed the wear pattern is offset like its only braking on outside half of rotor, but I do know the caliper on other side is wearing evenly but sticks and overheats sometimes, is it possible for this side to stick and cause only outside of rotor to wear?
