87 no start
Old Jul 27, 2011 | 07:00 PM
tndox's Avatar
tndox
Default 87 no start
87 dakota 3.9 willnot turn over checked all fuses, replaced starter rela, can start truck by jumping terminals on starter. dont know where else to look any input would be greatly appreciated thanks
Old Jul 27, 2011 | 07:33 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ignition switch, wiring to the switch.
I will move this to the Tech section of the 1st Generation Dakota Sub-Forum.
Old Jul 27, 2011 | 10:18 PM
siggie30's Avatar
siggie30
Two things come to mind..... The position of the gear selector rod on the steering column may be a little out. Try wiggling it while turning the key to start or put the gear in neutral and try. Secondly, check the neutral safety switch on the tranny to see if it has become loose, or a wire disconnected.
Old Jul 28, 2011 | 12:18 AM
g. man's Avatar
g. man
I had the same problem recently. I parked the truck, and when I went back 20 min. later it wouldn't turn over, and if I remember right the light's on my gauge cluster wouldn't work either. I got a ride to ORielley's and bought an ignition switch. That turned out to not be the problem, it was the lock cylinder. But since the switch was an electronic part i couldn't take it back :/ Anyways, I would purchase the cheapest one first, try it and go from there. You'll also need a special security bit to get it out. They were maybe 5 bucks, and included at least 20 different ones. I think I paid 80 $ all together for the ignition switch and lock cylinder. Good luck!
