Replacing rusted fuel lines along frame engine to pump in tank Help??
Old Jul 29, 2011 | 03:28 PM
qlty94's Avatar
qlty94
Default Replacing rusted fuel lines along frame engine to pump in tank Help??
Has any one done this ?I need to do the supply and return steel lines.I know I need high pressure on the feed line,will a double flare like on a brake line be ok? Where did you get fittings ,lines etc.TIA for any help
Old Jul 29, 2011 | 07:00 PM
festerw's Avatar
festerw
I got mine at the dealer, it wasn't too outrageous around $140. It included the lines all the way from the tank to the fuel rail.
Old Jul 31, 2011 | 02:02 PM
qlty94's Avatar
qlty94
Thanks festerw,were you able to lay in the new lines without putting the truck on a lift?I had heard the dealers don't have older parts in stock,I will be calling around Monday morning hoping I can find an assembly
Old Jul 31, 2011 | 04:46 PM
mazda7475's Avatar
mazda7475
don't know if this is legal where you live but i replaced my lines with high pressure fuel injection hose, i did put a single flare on the ends i cut, then put the hose on with a small clamp. 10 years later it's still all good. total cost was about $10.
Old Jul 31, 2011 | 08:20 PM
festerw's Avatar
festerw
I went with the complete set because of where the leak was and the rest of the lines didn't look all that great. I was actually surprised it was as cheap as that it included the pressure, return and vent lines as well as new flex lines to the tank and fuel rails.
I took the right rear off of the ground to give more room since I dropped the tank and replaced the fuel pump at the same time.
Old Aug 8, 2011 | 02:01 PM
qlty94's Avatar
qlty94
You were lucky I called a local dealer Parts dept. he checked his puter it shows no parts available for my 94 ex cab V6 at any dealers in the area so I am in the process of building a new set of lines.Quick connectors to nylon to steel to nylon Oh boy i'm getting a head ache .
