M1 intake Q
Old Sep 6, 2011 | 12:08 AM
Shelbyfan's Avatar
Shelbyfan
Default M1 intake Q
What is the part number for the drop in M1 intake manifold? All I can find is the manis for carb and before I spend the money I want to make sure I get the correct one.
My engine is going to get a rebuild soon as I can hear a very low but deep knock inside the engine. Probably do a 5.9 swap.
These would be the perfect trucks if the extended cab came with an 8' bed.
Old Sep 6, 2011 | 12:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It depends on what brand you wanted. Mopar makes them, (which will be the most expensive) to Eddlebroc (I think) to Hughes engines(probably best price). I think there probably are more. Try www.summitracing.com probably tons on www.ebay.com
From Mopar Performance catalog. http://www.mopar.com/performance/catalog.html
C. Aluminum Single Plane Intakes - MPI
Can be used as a direct replacement for production engines. Allows
use of air conditioning and all factory accessories. Designed to use
production throttle body, injectors, fuel rail and other hardware from
your stock intake. Available in EGR and non-EGR. Replacement for
stock.
1 P5007790 Intake Manifold, Aluminum, Single Plane, Two- or
Four-barrel EFI, Right Linkage, 5.2L/5.9L Truck
Magnum/Jeep Engines, Requires Modifications
1 P5007398AB Intake Manifold, Aluminum, Single Plane, Two-barrel
EFI with EGR, 1992-97 5.2L/5.9L Truck
Magnum/Jeep Engines, Requires Installation Kit
P5007638
1 P5007852 Intake Manifold, Aluminum, Single Plane, Two-barrel
EFI without EGR, 1998-2003 5.2L/5.9L Truck
P5007638
1 P5007638 Installation Kit, Intake Manifold, Two-barrel Intake
Only, 5.2L/5.9L Truck Magnum/Jeep Engines
http://www.hughesengines.com/Index/p...BBaXIgS2l0cyk=
http://www.edelbrock.com/automotive_...chrysler.shtml
My thoughts exactly! One day I still want to drop in a 8 foot bed on my club cab.
Old Sep 6, 2011 | 06:16 PM
Shelbyfan's Avatar
Shelbyfan
Did some more searching and only one will work (EGR), guess I should have looked under 5.9, and of course it is the most expensive at $650, although Mancini Racing has it for $545 but I know nothing about their store.
Old Sep 6, 2011 | 11:52 PM
Hahns5.2's Avatar
Hahns5.2
You can find them used well under $500 all day long.
Old Sep 7, 2011 | 02:56 AM
Shelbyfan's Avatar
Shelbyfan
All day long? I could find one and it was $600
Old Sep 8, 2011 | 12:24 PM
Hahns5.2's Avatar
Hahns5.2
Dakota-Durango.com They're for sale all the time.
Old Sep 8, 2011 | 10:25 PM
Shelbyfan's Avatar
Shelbyfan
Cool, I will check them out.
Thanks.
