Low Brake Pedal
Old Sep 10, 2011 | 01:46 PM
asosnoff's Avatar
asosnoff
Default Low Brake Pedal
1992 318, automatic 4 x 4. Brake light and ABS light came on, the I got a low brake pedal. Appeared low on fluid, I topped it off and found no leaks. Replaced master cyl., no change, still low pedal and lights. Hear a vacuum noise by brake pedal when applying brakes. Any thought appreciated.
Old Sep 10, 2011 | 02:40 PM
g. man's Avatar
g. man
Well I'd start by identifying the noise your hear. Vac leak or something? You should be able to figure that out by having a friend press the pedal whille your under there listening\ looking. You're not losing fluid though?
Old Sep 10, 2011 | 04:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Don't forget to bleed all 4 good.
Old Sep 11, 2011 | 05:27 PM
stevochar's Avatar
stevochar
your vacuum booster is bad. the diaphram inside is bad and leaks when you apply the brakes
Old Sep 15, 2011 | 05:44 AM
melodytoinvent's Avatar
melodytoinvent
I'd have to agree.
