Help!
Old Sep 12, 2011 | 07:11 PM
Rickb89's Avatar
Rickb89
Default Help!
I jsut bought a 96 dodge dakota v6. i was told it had a blown head gasket but after cleaning it up and runing it for a bit i found no signs of a leak internal or external. I took it on a test drive and 3/4 the way throught it stated to squeal loudly and i herd knocking. Oil pressure dropped, water temp was rising quick. I assumed the the oil pump was shoot due to the knocking and squealing. when i got it home i checked the oil and it was at least 2 quarts past full and smelt like gas.
My first thoughts would be a leaking fuel injector. i turned it over after letting it sit a day or two and there was still knock. Is it leaking injectors or internal damage or both? any help is appreciated.
Old Sep 12, 2011 | 07:21 PM
Rickb89's Avatar
Rickb89
I forgot to mention that when i first got the truck the fuel pump was dead. i waent to a junkyard and pulled a fuel pump off a newer dodge. Could it be that the pump has to much fuel pressure and caused all this?
Old Sep 13, 2011 | 02:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Lots of possibilities. Yes it could be leaking fuel injectors and too high of a fuel pressure regulator since it is in the fuel sending unit. Bad water pump for the sequel and overheating.
Old Sep 13, 2011 | 11:32 AM
qlty94's Avatar
qlty94
Return line clogged ??
Old Sep 13, 2011 | 11:27 PM
Rickb89's Avatar
Rickb89
Hmm since you mention the water pump i do know that the truck was siting for 3-4 years. The seller said that he poured quick seal in the coolant to stop a leak and it could have plugged the jackets and stopped coolant flow. Im pretty sure a different fuel pump is needed. My main worry is that the engine is junk from the injectors leaking and thinning the oil. I removed the valve covers today and it was dry not even oil on the lifters. So im hoping for best but planing for the worst.
