tailgate wont open
Old Sep 17, 2011 | 11:55 PM
4x4Dakota93's Avatar
4x4Dakota93
Default tailgate wont open
When I try to open the tailgate, it doesn't work unless I pull handle and stick skinny flattip on pass side lock tab and pull up to drop tail gate, how do I get in tail gate to adjust it?
Old Sep 18, 2011 | 12:43 AM
dodgerules86's Avatar
dodgerules86
On the other side of the tailgate (behind the handle), there is a panel with 4 screws. Removing the screws will give you access to the linkage.
You might need to adjust the striker (the thing the latch, well, latches onto). It's adjusted by loosening the torx bolt in the center of it, and moving the striker as needed.
Old Sep 18, 2011 | 02:31 AM
4x4Dakota93
Oh I got bed Liner, can't tell where screws r
Old Sep 18, 2011 | 06:04 AM
festerw's Avatar
festerw
Try cleaning and lubricating the latches first, I've found they get dirty and won't fully disengage.
