front brake help
ok..i need some help diagnosing a problem..i realize this is hard to do sometimes with out seeing/feeling the truck, but maybe someone can point me in the right direction...when applying the brakes, at very slow speeds, 5 or so mph or lower it seems, my front brakes seem to lock up..it doesnt happen at all when up to speed..only when pulling out of my driveway or creaping up to a stop in a parking lot..i know my rotors are shot and i plan to change them soon, but i think i may have a caliper piston sticking or something..like i said, i will just barely apply the brakes and from time to time, they lock up like i just slammed my foot down on them...bad caliper piston??
I had an OT vehicle that did that a few years back, it turned out that my rotor and pad on one side was worn to the point that the piston was overextended.
Proof came one day when I stepped on the brake and blew a crapload of brake fluid all over my apt. house parking lot
It could have been a serious pucker-factor moment in traffic, vowed never to push my luck like that again...
Better safe than sorry, better give everything a close inspection ASAP.
I had lots of fun with my front brakes. Once you have checked the major stuff, pads, calipers and so forth, if the problem is still persisting, I would check the actual brake lines that go to the caliper. For some reason, these will cause a sticking. Also, be careful when and if you remove the line, dont screw up your metal lines, those are a pain to replace.
good luck
good luck
good luck
good luck
Yes, there is some bendable tubing, make sure to get the stuff that you can bend by hand. Dont get too long of a piece since the ends are already finished and you dont want to route a bunch of excess tube.
I would change the flex brake lines while you are it. You will have to bleed the system anyway. Also be sure to watch out for chaffing, where a piece of line may sit there and rub against metal causing a hole.
g luck
g luck
