94 dakota wont start
Old Oct 7, 2011 | 11:13 PM
sjnewton's Avatar
sjnewton
Default 94 dakota wont start
Hi there I am not only new to this forum but also new to Dodge. I wanted a truck and found this 94 that seems to be in good shape. Picked it up today and drove it home. went to put it in the garage later and it would do nothing!! No lights on dash no sounds no start. I cleaned the batery terminals and was able to get dash lights but only dim. When I try to start it the starter just ticks but wont turn over. The battery is fully charged. I hope someone out there has some ideas cause the truck seems to be good.
Steve
Old Oct 7, 2011 | 11:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sure sounds like bad battery or bad cables or bad terminals or bad ground to the truck or bad power cable.
Old Oct 9, 2011 | 04:53 AM
RockGuardedDak's Avatar
RockGuardedDak
Check the ground connection on the battery. I had the same problem with mine when I bought it. It's just a bad ground. Or the positive terminal needs to be cleaned up too. What I did was I went to my local part store (Partsource) and just bought new terminals for it. I had subs that had to be wired in, so I was in need of new terminals anyway
Old Oct 9, 2011 | 08:20 PM
sjnewton's Avatar
sjnewton
Thanks for the reply. It was a bad battery and the starter also seemed to be bad, I could not get it to run off my other car battery. Changed both and now working well,
Steve
