biggest tires for v6?
Old Nov 15, 2011 | 05:53 AM
4x4Dakota93's Avatar
4x4Dakota93
Default biggest tires for v6?
Any of u guys have struggle with 3.9 motor turning big tires? 32s 33s or bigger?
Biggest I've ever had were 31s which were ok
Just for reference, my truck is 3.9l, with cold air intake, no cat and turbo shop muffler, with 3in exhaust, and jet stage 2 chip(despite what anyone says, had it on since 04 and it made big improvement)
Old Nov 15, 2011 | 11:23 AM
marcar1993's Avatar
marcar1993
With the right gears you should be fine. If you can tow thousands of pounds stock, the bigger tires will make little difference with the right gears.
Old Nov 15, 2011 | 12:18 PM
4x4Dakota93
Talking bout with stock 355s
Old Nov 15, 2011 | 11:16 PM
marcar1993's Avatar
marcar1993
Set up a ratio. New tire over current ratio to old tire over x.
33 . . . 31
3.55 . . x
33x=3.55(31)
33x=110.05
x=3.33
Your new effective gear ratio is 3.33:1. This means its as if you had a 3.33:1 rear gear with your current tires. Considering they DID make 3.21 gears for these trucks I'm sure you're fine.
