95 Dakota starting problem
Old Nov 25, 2011 | 11:57 AM
lightsrus's Avatar
lightsrus
Default 95 Dakota starting problem
No spark at coil to distributor. Wire and coil resistence is good. 12 v power is at coil when ignition is turned on test light full brightness as well. Dimmed test light with indication of pulsing when starter is engaged. why no spark? Thanks for any input.
Old Nov 25, 2011 | 12:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Possibly bad crank or cam sensors or the notorious power spices. Any check engine light codes? Are you getting fuel?
I will move this to the 1st Generation Dakota sub-section.
Old Nov 25, 2011 | 05:20 PM
lightsrus's Avatar
lightsrus
thanks. found a ground missing that corrected the problem Thanks for your reply.
