Where to find Original 'OE' Parts?
I just picked up an old Dakota and Im about to do a major tune up. Looking for advice on where to find parts for my new-to-me first generation Dakota. This board has been very helpful so far.
I dont have a manual but I prefer to get everything exactly as the book calls it or maybe some good aftermarket options
Any recommendations about the following parts and information about where to find them is much appreciated:
1. Spark plugs/wires, Cap + Rotor
2. Fuel, Oil, Air filters.
3. Transmission fluid, Front/Rear Diff fluids, Power steering Fluids, Engine oil.
4. Wheel bearings
5. Steering rack bushings
J
4. Wheel bearings
J
For OEM the best place is your local Dodge dealership parts department.
Or www.dodgeparts.com or http://www.moparpartsamerica.com/spl...?siteid=214583
Most autoparts store will carry all that you listed and for 1/3 the price of Mopar.
Napa is trusted for quality parts. www.napaonline.com
Thanks for the help.. Liking how active this board is.
Any preference for fluids in diff/gearbox,,engine? The mopar 80/90 is expensive.
Also what should I do about a loose stearing wheel ? ? ..thinking about changing the rack bushings but the parts guy at my dealership didnt see any of them on the diagram.
Just because it says OEM Mopar doesn't make it true.
Here's a website with a lot of nationwide dealerships with an online store.
http://www.partswebsite.com/dodge.php
When you order through them, it's shipped from the dealership you choose (usually same or next day)
They also have references to every other OEM make as well.
Trending Topics
4. Wheel bearings
J
4. Wheel bearings
J
When I replaced my cap and rotor, anything was an improvement because the rotor spring was bent up and twisted 15 degrees to the left and the cap was cracked by what seems the previous owner installing it with a hammer.
I used the Autolite 3923 plugs because they disperse heat from the pistons faster, and others say it's because they're 1 stage cooler than stock and reduce pinging (these are for my 318 though).
Automatic transmission fluid is ATF+4, and ATF+4 in the transfer case as well. I use Walmart Supertech because it's on the list of qualified brands and costs $4.29 a quart as apposed to $6.99 a quart for valvoline at Autozone.
I use Valvoline Durablend Synthetic 80w-90 gear oil in the front and rear differentials...I have a thing for Valvoline, I guess.
For Power Steering, I just used the Autozone brand, and the same for brake fluid, just be sure it's Dot 3 and don't mix synthetic with non-synthetic fluids.
Engine oil? You guessed it, I'm using Valvoline (non synthetic). Some prefer synthetic, but I got this truck with 113k on it and had always heard not to use synthetic oil in a high mileage engine if it hasn't been used throughout already.
Bushings aren't going to cost you a lot more from the dealer, but if you buy Chinese bushings, in the long run you'll regret not paying the extra 10-15%.
I know you didn't ask, but lower control arm bushings are going to be on your agenda sooner or later, and there's a link in the FAQ section for those.
Napa is a good place for the bearings and bushings if they carry them in your part of the globe...mine doesn't.
Also, if you haven't done so yet, it's a good idea to run three bottles of Chevron Techron fuel/injector cleaner through. The bottle says it treats 12 gallons, but I run a bottle through 7 gallons, then run it to 1/4 tank, add another bottle and 7 gallons, then run it down to 1/4 tank, and add another bottle and 7 gallons (I hate running my tank lower than 1/2 tank, and refuse to run it lower than 1/4, or risk sucking crud into the filter)...you really will notice the difference after three bottles.
I also run premium Chevron gas because I feel it's better for our trucks...well, any vehicle really. Chevron gas has the Techron added to it. If you have the 2.4 you won't need the premium though.
I forgot to mention, you can download the Factory Service Manual in FAQ's too.
Depends on the year, the older trucks all had external filters also. I think 94+ only had in tank filters.
I don't know what year it started, but I can tell you guys that BOTH of my '93's have external fuel filters along the frame rail
