Proprietary Positioning of TPS
Old Nov 30, 2011 | 05:15 PM
azvampyre's Avatar
azvampyre
Question Proprietary Positioning of TPS
I was just pondering if it makes a difference which way the TPS is installed.
It either ***** 11 degrees counter clockwise, then twist it to line up the mounting torx, or cocked 21 degrees clockwise and twist it the other way to line up the torx..
Does it matter if I mount it clockwise offset and twist it counter clockwise to line up as apposed to mounting it counter clockwise offset and twisting it clockwise to line up?
Old Dec 1, 2011 | 06:47 AM
bwdakrt's Avatar
bwdakrt
Counter clockwise with the electrical connector to the bottom. Screws just need to be snug so don't over tighten.
Old Dec 1, 2011 | 08:38 PM
azvampyre's Avatar
azvampyre
Awesome. That's how I installed it. I just wanted to be sure since my acceleration dropped a little. Thank you.
