hazard lights
Old Dec 14, 2011 | 10:24 PM
vulch's Avatar
vulch
New Member
Default hazard lights
Hi 94 318 hazard lights not working checked fuses i think where would that fuse be .tried a used flasher no difference all other lights work the strange thing is when i push the hazard light switch on the turn signals dont work turn hazards off signals work Thanks
Old Dec 15, 2011 | 02:01 AM
Crazy4x4RT's Avatar
Crazy4x4RT
There are fuses under the hood, did you check those? Did you change the hazard flasher or the blinker flasher, 2 different ones. As for the blinkers not working when the hazard button pressed, it is suppose to be like that.
Old Dec 15, 2011 | 09:15 AM
misfitdakota_95's Avatar
misfitdakota_95
check by your underhood fuse box (near the battery) for the fusible link for the emergency flashers. The wire is a pink wire. If that fusible link blows, you will lose your emergency flashers. What I did when that happened to me was install a wire with a fuse holder in place, put a 15 amp fuse and everything works just fine. You might have to remove the wiring harness from the protective sheath to access the pink fusible link.
Old Dec 15, 2011 | 06:21 PM
vulch's Avatar
vulch
New Member
Hi i checked the 20 amp fuse under the hood its good i will look at the fusible link thanks
Old Dec 30, 2011 | 02:29 PM
vulch's Avatar
vulch
New Member
Hi still working on hazards tried 2 other used Multifunction switches no change so i have opened some of the wiring harness near the fuse box next to the battery looking for a fusible link not sure what they look like .i do see wires that look like they have heat shrink on them is that it there are several .Thanks
