Hi. I'm going to change the door on my 93. I had planned on doing it by way of the pins. I read somewhere to just unbolt the hinges from the body instead. Is either way easier or better? Is there an issue at all with either? Which way would most of you do it?
Thanks
Just unbolt it! 2 bolts per hinge, super simple. You WILL have to line up the door to get the gaps right, not every door is not the same. You can use a marker to trace where the hinge was to get it close at first then adjust as you go.
Yeah, got the top pin to move. The bottom, well, I'll have to remove that chrome running board. Can't get a good hammer swing with it right below. Got a helper today.
Thanks guys
