headlight problem
Old Jan 25, 2012 | 09:31 AM
taterhead's Avatar
taterhead
Default headlight problem
95 dodge dakota headlights go on and off by themself any suggestion on what might be the problem???
Old Jan 25, 2012 | 02:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Possibly the switch which has an internal circuit barker.
I will move this to the 1st Generation Dakota Sub-Forum.
Old Feb 6, 2012 | 08:24 AM
92_4x4's Avatar
92_4x4
does it do it on the high beams or just in general? mine was doing the same thing and it was a loose connection at the on/off switch. i put in a new one and it fixed the problem but for some reason if i have the high beams on to long it pretty much over heats ( the switch that is ) and shuts off. but if i put back on low beams they work again. so i would start there. pull the trim panel and have headlights on and wiggle the connector around and see if they go on and off.
Old Feb 7, 2012 | 08:54 AM
89newbie's Avatar
89newbie
Our 89 needed a new switch. It did it for a month or so then went to no high beam. Switch fixed it.
