One Dim headlight...
Old Feb 26, 2012 | 02:59 PM
dblackmanc's Avatar
dblackmanc
Default One Dim headlight...
'95 SLT V6 5Spd.
I have one headlight (Drivers side) that is dimmer that the other. I've removed bulb and checked voltage and ground at the plug. All looks good but that is without any load? I have changed bulbs from left to right but the problem remains on the left side. So I figure my problem to be a poor ground or low voltage on that side only? So I'm looking for suggestions on how to test and determine where my prolem is located? All wires just disappears into the harness. Does anyone know where the ground is attached for this headlight? or where to test for low voltage?
Thanks...
Dan
Old Feb 26, 2012 | 04:33 PM
shadowthedakota's Avatar
shadowthedakota
Check the ground wire on the left fender around the relay box area.
Old Feb 29, 2012 | 09:07 PM
dblackmanc's Avatar
dblackmanc
Shadow....
I checked, cleaned and attached the ground wire on the drivers side fender well...No change! I also did the same to two ground wires on the fire wall, one on the brake servo and one from the battery to the rear of the grill area....still no change!
Any more suggestion?
Dan
Old Mar 3, 2012 | 02:06 AM
9652dakota's Avatar
9652dakota
best suggestion i have is to cut the ground wires at each bulb connector and run a new one. then go to the harness at the left side where the dash harness comes through the fire wall. cut the low and high beam wires. you then would use those as signal wires for relays. this takes the load off of the switch and boosts the juice to the bulbs. it's a huge help in it's own. while you are at it you could even set it up for qaud beam. same as above but you would add a third relay that would fire from the high beam wire to the low beam aswell. it's a simple set up that is very effective. you retain all functionality and there is the added bonus of if you decide later to do bixenon bulbs or bixenon projectors your harness is set up for it already!
i used 25 amp breakers (not fuses. fuses work fine just a personal thing) with the normal 30 amp relays.
the basics are solder all the connections and heat shrink them.
use dielectric grease on all connectors (relays and fuses/breakers)
use wire loom to dress it up.
for a cleaner look head to a junk yard and find an old nissan. they had a bank of four relays in a nice little box that is great for this. makes for a nicer install. when you finish this the wires would be
pin 85 for ground on all relays
pin 30 for battery power (fuse this ckt)
pin 86 is where the wires for high and low from the switch would connect.
pin 87 is for the lights themselves.
for quad beam your low beams would have one relay connected to the low beam wire.
then the lows have a second that is turned on by the high beam wire.
then the highs have one turned on by the high beam wire.
the purpose of two relays connected to the high beam is to isolate the two ckts so that you have seperate high and low beams.
now this can be done with 2 relays and the high triggering both and a diode to keep the low beam from turning on the high beam. but this set up is also easily disabled to go back to normal lights. either way will fix your problem and help out with overall output. i suggest the relays though.
oh and also the relays would give you the option to add fog lights for lowbeam supplement that could easily be set up to switch off when going to high beams if you don't have them from the factory.
one last piece of advice is when you hook up the output (pin 87 to power bulbs) cut the wire at the left light in two then solder the three together. then the ckt doesn't have to be overylayed with bigger wire since the load is cut in half for the part of it from the switch.
Old Mar 4, 2012 | 09:12 AM
dblackmanc's Avatar
dblackmanc
Thanks 9652Dakota....
Great info. I'll start the change over soon.
Dan
Old Mar 5, 2012 | 01:04 PM
9652dakota's Avatar
9652dakota
no problem. i hope it goes painless for you.
