94 Dakota tranny with t-case
I found a 4wd automatic transmission with t-case for my 94 v6 Dakota. But the problem is my truck is 2wd!
So my question is, can I just remove the t-case and bolt it up to my 2wd?
THANKS!
THANKS!
No you can not. The only way is to 100% remove all the internals just to swap the output shafts. But if your removing all the internals you might as well rebuild yours, kits are around $200 at Napa. We have the factory service manual in the FAQ which has a transmission rebuild section.
