need brake help
Old Mar 16, 2012 | 09:27 PM
melodytoinvent's Avatar
melodytoinvent
Originally Posted by jvanhoe
The brake pedal goes all he way to the floor and I can hear a hissing sound as I depress the brake pedal. Pressure doesn't build up as I pump the brakes. So the thought is the Master Cylinder not the brake booster? What about the Master cylinder moving back & forth as the brake pedal is pumped?
That doesn't count..at all? Lol. Or are you looking for something more? Either way I'm just saying what I said cause outta nowhere my pedal hit the floor in the Durango and I checked all the little stuff and didn't see leakage anywhere and thats when I took it to the shop and they found the wheel cylinders leaking which is what I expected cause it was the same symptoms as my Dakota. I'm only throwing it out there as something else to check.
Old Mar 17, 2012 | 09:10 AM
dodger8691's Avatar
dodger8691
lol sorry didnt see that must not have been paying attention when i read it then yea it sounds like the master cylinder
Old Mar 17, 2012 | 07:00 PM
jvanhoe's Avatar
jvanhoe
As I said before the pedal goes to the floor but I haven't had a chance to see if thc booster is moving when the Master cylinder moves. I will pull off the rear wheels/brake drum to check the wheel the wheel cylinders but since the Master cylinder stays full, I don't think they are leaking. Any recommendation for a Master cylinder? I checked at the local parts store/ebay and prices can range from $20+ to $70+.
Old Mar 17, 2012 | 10:09 PM
dodger8691's Avatar
dodger8691
www.rockauto.com there great for getting stock replacment parts at a reasonable price and timley shipping too i use them for my camaro Hyundai and my truck
