The search for small rims
Old Mar 24, 2012 | 12:15 AM
T.C.'s Avatar
T.C.
Default The search for small rims
Hello there guys, I am on the search for small rims "diameter wise", maybe looking for a 12-14 inch rim or smaller, does anyone know if there is a bran of rims that match our bolt pattern for that, I did the search using other vehicles withour bolt pattern and no luck, most are growing larger in diameter. If not you think it is wise to get rim adapter for a different bolt pattern? I am also conscious about the potential problem relating to the braking system and the maximum size to cruise at.
Old Mar 24, 2012 | 01:08 AM
festerw's Avatar
festerw
I don't think anything smaller than 15" will clear the calipers. Even at that on some trucks the banjo bolts need ground down to fit Gen 2 15's.
Old Mar 24, 2012 | 04:02 PM
bill55az's Avatar
bill55az
early dakotas, the ones with 5 lug wheels, were available with 14" wheels.....but yours is the newer 6 lug and 4.5" bolt pattern.
You would have to have them made by modifying the bolt pattern of whatever 5 lug wheels you find....
and going smaller than 14" will likely cause some brake clearance issues...
There are people out there who will make adapters....try ebay.
