new look to my slt
Old Mar 24, 2012 | 09:00 AM
dodger8691's Avatar
dodger8691
Default new look to my slt
when i bought it it was all grandpa-ed out
then i switched the wheels and tires to the durang 15in with 31x10.5 hercules trail diggers M/T
then i took off the cap and now it looks 100 times better
but when i put the wheels on i had a problem with the bolt for the brake hose grinding on the rim i had to grind the bolt down so the wheels would work i thought they were supposed to be a direct fit?
next is a simple exhaust to give it a little rumble and then replace all the light lenses (i bought the truck from NYC so it has cracks in all of them)
Old Mar 24, 2012 | 12:14 PM
Sauxon's Avatar
Sauxon
The wheels are not a direct fit. What you had to do is exactly what others have had to do. I like the look of those tires. I will be needing some soon however I have decided that I will get the body lift so that I can fit 33s when I buy new ones (already done the torsion bars and aal)
Old Mar 24, 2012 | 05:14 PM
dodger8691's Avatar
dodger8691
my options were to grind down the bolt for the brake hose or put the shot tires back on so i decided to grind the bolt so now its good to go
Old Mar 26, 2012 | 11:34 AM
marcar1993's Avatar
marcar1993
On second gen 16" wheels, the brake bolt isn't a problem though is it?
Old Mar 26, 2012 | 05:15 PM
Sauxon's Avatar
Sauxon
I havent tried but I imagine so
I believe the only reason why the 2nd gen 15s are a problem is because they are wider. Correct me if I am wrong. But if they are bigger rims then it should be fine
Old Mar 29, 2012 | 11:48 PM
VINCE 91's Avatar
VINCE 91
Very nice truck!
Old Mar 31, 2012 | 11:16 AM
dodger8691's Avatar
dodger8691
yea the only issue was that they were wider i want to do it the right way and get the wheel spacers so i cna replace that hose when the time comes but i dont know what size spacer to get and i want to get the same spacing for the back as well so its even all around
