wiring harness and cluster?
Old Apr 5, 2012 | 11:00 PM
chet.manly's Avatar
chet.manly
Default wiring harness and cluster?
i have to replace the wiring harness off my 93 le 5.2 because some dumbass rigged the injectors together. so my question is will a wiring harness off a 94 slt 5.2 match?
another question i have, if my the only working gauges in my cluster is the rpm and battery is there a way to fix the others or should i just replace it?
Old Apr 5, 2012 | 11:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
As for the injectors yes that wiring harness will work. As for the gauges, possibly a bad ground or some bad wiring. The service manual has the wiring diagrams to help you out.
Old Apr 6, 2012 | 12:30 AM
chet.manly's Avatar
chet.manly
alright.. thanks ill check that out tomorrow!
