transmission
I just did the trans lines, filled with atf4 and now i dont have reverse, neutral, and my truck is stuck in 3rd gear even when i manually put it in 1st or 2nd (auto).
Are you sure you got the level correct?
Ill check again today in the light but will me not being able to put it in neutral effect the reading?
It was actually high. I will fix level today I bought a new trans filter, should I just change it while I'm at it. I heard trans filter changes on high mileage vehicles isn't always good to do. Thanks
If you never changed the filter, then it is good to do it. You will need new fluid to refill it.
Didn't change anything. There were metal shavings in the pan. If I'm rolling slowly and I put it where neutral and reverse should it all locks up. I don't know what to even check outside of the trans.
