biggest tires on a stock 1st gen dakota
so a real quick question: what's the biggest size i can fit under a stock 4x4? the stock size is 215P75R15, the size its got on right now is 235P75R15. can i go any bigger? btw, i have the stock aluminum rims. can i go taller or wider or both? i really don't want any rubbing. i plan on going with BFG A/T's.
thanks,
rampagefan
thanks,
rampagefan
right, but i have heard that the tire width cannot be more than 2" bigger than that of the rim width. so would a 30x9.5x15 be too big for the stock aluminum rim which is 6" wide, i think?
I've got 33x10.50s on my stock rims w/ a 4" lift. I have some rubbing against the frame at full turn, as well as some fender rub when I am turning and hitting a hard bump.
The 10.50s actually don't go out past the fender flare at all either, I was happy about that.
