door panel/speaker removal
Old Apr 17, 2012 | 07:06 PM
93MissDakota's Avatar
93MissDakota
Default door panel/speaker removal
so i got some new speakers for the doors but before i go at pulling the door panels off, any tips for not breaking clips or anything i should be aware of? it looks like its never been pulled so i dont wanna f anything up
Old Apr 17, 2012 | 09:59 PM
Motorcharge's Avatar
Motorcharge
May be different on 93, but on my 90 I didnt need to pull the whole panel. The speaker cover popped right off and provided more than enough room to work with.
Old Apr 18, 2012 | 12:33 AM
melodytoinvent's Avatar
melodytoinvent
Are you referring to the back speaker grill or the door panel? Cause the back is pretty simple but you do have to be a little careful with the door panels.
Old Apr 18, 2012 | 01:52 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yup the 91?-up did not have the pop of speaker panel.
The door panel only has 2 screws on on the mirror corner and 1 in the arm rest pocket. The rest are metal clips, just pull the panel out, nothing to break.
Old Apr 18, 2012 | 10:35 AM
93MissDakota
thanks, im gonna install them shortly
Old Apr 18, 2012 | 02:29 PM
kahanabob's Avatar
kahanabob
use a screwdriver between panel and door and pop each one out. when you put back together make sure the clips are lined up with the holes and pop them back in.
