wheel speed sensor
Old Apr 26, 2012 | 03:04 PM
chet.manly's Avatar
chet.manly
Default wheel speed sensor
I've been told that my wheel speed sensor was bad in my 93 318 and I was told that it could possibly fix my speedo and my shift problem but the problem I'm havin is that I'm not sure where its at. Ive researched it and I've found that there's some on the trans and some on the rearend
any help will be greatly appreciated
Old Apr 26, 2012 | 05:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The speed sensor for the PCM is on the rear of the transmission(2wd) Transfercase(4wd).
The ABS Speed sensor for the ABS system only is on the top center of the rear diff.
Old Apr 26, 2012 | 09:42 PM
chet.manly's Avatar
chet.manly
thanks I'll check that out when I get daylight!
Old Apr 26, 2012 | 10:04 PM
chet.manly's Avatar
chet.manly
anyone got a pic of what the sensor looks like? I'm thinkin bout ordering one on ebay but I'm not sure what they look like..
Old Apr 27, 2012 | 12:21 AM
Brian1008's Avatar
Brian1008
if you ever want to see what a part looks like go to autozone.com It will atleast give you a good idea.
