no start on 89 sport
Old Apr 28, 2012 | 12:37 PM
mazda7475's Avatar
mazda7475
Default no start on 89 sport
i read the faq on the splice but the 89 is a different set up, there's no relay center just 4 relays bolted to the fender - starter, asd, front fog lights and roll bar fog lights (sport with factory roll bar and fog lights).
girlfriend went to start the truck and nothing, it rolls over and plenty of spark. the asd clicks when the key is turned on so it's getting power. put some gas down the throttlebody and it started for a few seconds. stuck my finger under one of the injectors while she rolled it over and no fuel. when it put my finger against one of the injectors i could not hear or feel it clicking, i also could not hear the fuel pump load up when the key is turned.
seems to be no power to the pump or injectors.
Old Apr 28, 2012 | 12:49 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a bad fuel pump or no power to it. First test the wiring connector to the fuel pump and see if it is getting correct power. If good power then its a dead pump. If you don't have power then find the culprit fuse cut wire ect then fix it.
Old Apr 28, 2012 | 04:59 PM
mazda7475's Avatar
mazda7475
the injectors seem to have no power either.
