Fuel check valve install
Old Jan 2, 2020 | 07:08 AM
RalphP's Avatar
RalphP
David Mann - it's not so much in front of or behind the fuel filter, it's as close to the pump as possible. In front of the fuel line is just close. What you CAN do is trim that line from the pump (the hard line), flare it enough to help it seal, then use a 92/93 filter instead. Or swap to the 92/93 filter, and that'll call for about 14" or so of inlet hose so you can loop back and back to the front.
RwP
Old Jan 2, 2020 | 09:39 AM
David Mann's Avatar
David Mann
Default Return line
What about the return line . What keeps fuel from flowing back through line ?
Old Jan 2, 2020 | 09:51 AM
RalphP's Avatar
RalphP
Who cars if fuel flows that way? Matter of fact, you don't want any restriction on that line - a common upgrade to the high-HP Thunderbirds is to make both inlet and return lines 3/8" or 1/2" to keep enough fuel flowing both ways.
It's the RETURN line, after the regulator, so as long as the FEED line is pressurized, you're good.
Think about it ...
RwP
Old Jan 2, 2020 | 10:01 AM
David Mann's Avatar
David Mann
Think about it ...
RwP
Thanks for the information . I'll post up after everything is installed .
Old Jan 2, 2020 | 10:26 AM
onemore94dak's Avatar
onemore94dak
wrong place
Old Jan 9, 2020 | 02:40 PM
David Mann's Avatar
David Mann
Default Check valve installed.
I will post up tomorrow morning how it starts after sitting over night .
Old Jan 10, 2020 | 05:43 AM
David Mann's Avatar
David Mann
Default Fired right up.
Went out and started it this morning and it worked like it should . Glad I found this information. Thank you for all the input. We can keep these old Dakotas going !
