3.9 facotry specs
Old Aug 18, 2005 | 12:45 PM
trukn2004's Avatar
trukn2004
Default 3.9 facotry specs
I was wondering if anyone knew the factory specs on a 3.9 V-6 with the manual tranny. mostly the horsepower and torque. Thanks
Old Aug 23, 2005 | 04:06 AM
Natedogg625's Avatar
Natedogg625
Default RE: 3.9 facotry specs
Engine Type
238 cid 90deg V-6 OHV
1997 HP Curve
1994 engine serial no. stamped into a machined pad on the left front corner of the engine block.
X M 3.9L T XXXX XXXXXXXX
* X= Last Digit of model year
* M=plant - M Mound Road
* S Saltillo
* T Trenton
* K Toluca
* 3.9L = Engine displacement
* T= Usage - T Truck
* XXXX = Month/day
* XXXXXXXXX = last 8 VIN digits
2001-2001 serial no:
X M AAA YYYY XXXX
* S Saltillo
* T Trenton
* K Toluca
* AAA Engine displacement (cid)
* YYYY = Month/day
* XXXX = Engine Serial code
Horsepower
175 hp @ 4400 rpm
Bore x Stroke
3.91 x 3.31 in.
(99.3 x 84.0 mm.)
Displacement
238 cu.in. (3.9 L)
Compression Ratio
9.1 :1
Cylinder Compression Pressure
100 psi
Torque
230 ft. lbs. (312 N.m) @ 3200 rpm
Firing Order
1-6-5-4-3-2
Lubrication
Pressure Feed - Full Flow Filtration
Engine Oil Capacity
4.0 Qts. ( 3.8 L ) with filter
Oil Pressure
Idle 6psi
3000 rpm 30-80 psi
Oil pressure warning
5-7 psi
Cooling System
Liquid Cooled - Forced Circulation
Cooling Capacity
15.1 Qts. (14.3 L)
Cylinder Block
Cast Iron
Cylinder Head
Cast Iron
Combustion Cambers
" Fast Burn " Design
Pistons
Aluminum Alloy with Strut
Distributor Rotation
Clockwise
Spark Plugs: 14mm thread, 19mm reach, 16mm hex wrench, resistor
Year Manufacturer Part No. Stock Number Gap Notes
1994-1996 NGK FR4 5155 .035
1997-1999 NGK FR5-1 7252 .040
Camshaft - Nodular Cast Iron
Bearing Number 1 2 3 4
Bearing Diameter mm 50.800 - 50.825 50.394 - 50.419 49.606 - 49.623 39.688 - 39.713
in 2.000-2.001 1.984-1.985 1.953-1.954 1.5625-1.5635
Journal Diameter mm 50.749-50.775 50.343-50.368 49.555-49.581 39.637-39.662
in 1.998-1.999 1.982-1.983 1.951-1.952 1.5605-1.5615
Diametrical Clearance: 0.0254-0.0762 mm, 0.001-0.003 in
Max Allowable: 0.127 mm, 0.005 in
End Play: 0.051-0.254 mm, 0.002-0.010 in
Connecting Rods - Forged Steel
Bearing Clearance . . . . . . . . . 0.0127-0.0559 mm, 0.0005-0.0022 in
Piston Pin Bore Diameter . . . . 24.940-24.978mm, 0.9819-0.9834 in
Side Clearance (two rods) . . . .0.152-3.356mm, 0.006-0.014 in
Total Weight (less bearing) . . . 726 grams, 25.61 oz
Crankshaft - Nodular Cast Iron
Connecting Rod
Journal Diameter . . . . . . . . . . . . . 53.950-53.975 mm, 2.124-2.125 in
Out of Round (max) . . . . . . . . . . 0.0254 mm, 0.001 in
Taper (Max) . . . . . . . . . . . . . . . . . 0.0254 mm, 0.001 in
No 1: . . . . . . . . . . . . . . . . . . . . . . . 0.0127-0.0381 mm, 0.0005-0.0015 in
No 2, 3, and 4 . . . . . . . . . . . . . . . . 0.0127-0.0508 mm, 0.0005-0.0020 in
Max Allowable (Nos. 2, 3, & 4) . . 0.0635 mm, 0.0025 in
End Play . . . . . . . . . . . . . . . . . . . . . . . 0.051-0.178 mm, 0.002-0.007 in
Max Allowable . . . . . . . . . . . . . . . . 0.254 mm, 0.010 in
Main Bearing Journals
Diameter . . . . . . . . . . . . . . . . . . . . 63.487-63.513 mm, 2.4995-2.5005 in
Out-of-Round (Max) . . . . . . . . . . . 0.0254 mm, 0.001 in
Valves
Stem to guide clearance
* 0.001- 0.003 inch
* maximum allowable (rocking method) 0.017 inch
Guide Diameter (std) 0.313 - 0.314 inch
Intake
Exhaust
Face angle 43.25 - 43.75 degrees 43.25 - 43.75 degrees
Seat Angle 44.25 - 44.75 degrees 44.25 - 44.75 degrees
Seat Width 0.040-0.060" (1.016-1.524mm) 0.060-0.080" (1.524-2.032mm)
Head Diameter 1.916 inch (48.666mm) 1.624 inch (41.250 mm)
Length Overall 4.893 - 4.918 inch 4.907 - 4.932 inch
Stem diameter 0.311 - 0.312 inch 0.371 - 0.372
Valve Opens 8 degrees BTC 56 degrees BBC
Valve Closes 65 degres ABC 25 degres ATC
Duration 250 degrees 264 degrees
Valve Overlap
31 degrees
Valve Lift (zero lash)
0.432"
Push Rod Length
6.915-6.935" 175.64-176.15mm
Valve Springs
* Free length 1.967" 49.962mm
* Installed height 1.64" 41.66mm
* Spring Tension
o Valve closed 85 lbs @ 1.64"
o Valve open 200 lbs @ 1.212
* Number of Coils 6.8
* Wire Diameter 0.177" 4.50mm
ALL of the specs for the V6, I mean ALL the specs
hope this helps
Oh and dont worry about the years the engine was the same until 2004
