club cab rear seat removal?
Old Jun 3, 2012 | 07:32 AM
95REDKOTA3.9's Avatar
95REDKOTA3.9
Question club cab rear seat removal?
hello i was wondering how do i remove the back and side cushions/rear seat the right way? Also does anyone know if that plastic storage tray under the seat is removable or is it very difficult to remove (ie. removing front seats and carpet)? if these things are easy to moderate to accomplish i would like to do a writeup on it just in-case someone else want to do a similar thing. just in case anyone was wondering why i want to do all this i want to get the most space for a full custom dual kicker 10" sub enclosure.
Thanks in advance
Old Jun 3, 2012 | 12:56 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
I had to remove the rear seats to clean the interior of my truck. When I bought it it was absolutely disgusting inside. The piece above the rear seat cushions just pulls off then you'll have access to the bolts that bolt the back cushions on. Once you remove the back cushions then you'll have access to the lower seat brackets/hinges. The lower trays are just screwed in but I had trouble removing mine. The nuts that are attached to the body were spinning. It took a little extra work. The side cushions are attached to the side panels.
A.J.
Old Jun 6, 2012 | 03:36 AM
95REDKOTA3.9
so is there any way to remove the side cushions either by removing the panels or just ripping them off? they are never going back in because im filling the near useless seats to put in a rather large sub box.
Old Jun 6, 2012 | 10:14 AM
AZ 360 Dakota
Possibly. You'll have to pull the panels and see if they attached from the back side. I don't remember if they are or not.
A.J.
