Replacing inner tie rod ends - 1995 Dodge Dakota
Old Jun 10, 2012 | 03:03 PM
WolfStar's Avatar
WolfStar
Default Replacing inner tie rod ends - 1995 Dodge Dakota
Hello,
Is it difficult to replace the inner tie rod ends on a 1995 Dodge Dakota 5.2L V8 with 2WD?
I am going to be doing ball joints and outer tie rods ends and thought I would do the inners as well.
Is this a big job? Can someone give me the procedure. Doesn't seem to be anything in the factory service manual.
Thanks
Old Jun 10, 2012 | 06:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
By looking at the pictures in the manual it looks like just remove the boot and un-thread the inner tie rod from the rack and pinion. But I'm not to sure they are something that may need to be replaced.
Old Jun 10, 2012 | 11:58 PM
WolfStar's Avatar
WolfStar
So you think inners are not a major maintenance item? Maybe I'll just do the outers and see if there's any slop. The inners are much more expensive, whereas the outers are relatively cheap.
