Cylinder misfires
Old Jun 16, 2012 | 10:09 AM
Biking_Dodge's Avatar
Biking_Dodge
Default Cylinder misfires
The check engine light has come on and the message on an OBD reader is "cylinder misfire" on all 8 cylinders. Any suggestions where to start further diagnosis?
Old Jun 16, 2012 | 11:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Please give more info.
What year of the truck?
I can move this into the correct sub-forum.
Old Jun 18, 2012 | 07:45 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by Biking_Dodge
It is a 1996 Dakota, 5.2L engine with about 115,000 miles. Thanks for your help!
I will move your post to the 1st generation Dakota sub-section.
How does the engine run?
Have you checked how the spray is on each injector?
Have you checked your fuel presser?
Have you changed your spark plugs and wires and cap and rotor?
Have you checked your coil?
Old Jun 20, 2012 | 11:28 PM
hemispheres's Avatar
hemispheres
My first reaction indicates a PCM failure. Check the other suggestions as listed above. Reman PCM from O'Reilly approc $150.00.
