What transmission do I have?
Old Jun 19, 2012 | 06:34 PM
Jesse95's Avatar
Jesse95
Default What transmission do I have?
it's a 1988 dodge dakota, 3.9l v6, 2wd, long bed, single cab. soon to be SAS.
From my understanding it should have an a-500 transmission, but A-904 is cast into the bottom of the bell housing. and if it is an a-904, will a np242 transfer case bolt to it? With the exception of a different tail shaft of course.
and if it will, will it hold up to 33's with 4.10 gears?
Old Jun 19, 2012 | 06:42 PM
volaredon's Avatar
volaredon
does it have OD?
Old Jun 19, 2012 | 07:23 PM
Jesse95's Avatar
Jesse95
I honestly have no idea. I've never counted how many times it shifts, and I don't have a tach. what mph should it kick in at?
Old Jun 19, 2012 | 08:25 PM
dobaroy's Avatar
dobaroy
Do you see a button on the left hand side of the dash that has OD marked on it?
Old Jun 19, 2012 | 08:29 PM
Jesse95's Avatar
Jesse95
I just measured it and it's 31". so according to this http://www.carcraft.com/newlook/crc_.../photo_02.html that makes it a 904.
so my question now is, will a 242 transfer case out of a jeep bolt up to it? with the exception of changing the tail housing and output shaft.
Old Jun 20, 2012 | 01:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Bolt pattern will be the same. But the input shaft spline count on the transfer cases may be different. Best way to find out is to physically check both.
Old Jun 20, 2012 | 09:11 AM
Jesse95's Avatar
Jesse95
Thanks crazy thats what I needed to know. I expecyed the input shaft to be different but if I read correctly in a different thread I can use the input shaft out of of a 231 case, correct?
And no overdrive button?
