still fighting injector issues
Old Jun 25, 2012 | 02:39 PM
Danton88's Avatar
Danton88
Default still fighting injector issues
I have been trying to track down this intermitten injector #3 issue here is what i have done so far:
Replaced injector #3 old injector tested bad
Replaced injector connector due to not fitting tight connection
even ran a jumper wire from the ecm pin which is the yellow white along with tapping into another green red wire and by passing the old wires.
Fuel pressure is Around 35 psi at idle.
any ideas would be greatly appreciated
Thanks
Old Jun 25, 2012 | 05:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
One possibility is the positive splice supply for the injector. Try temporarily adding in a direct positive to the battery, see if that works.
Next possibility is the PCM is bad.
Old Jun 26, 2012 | 12:56 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Ya, you could have a bad #3 injector driver in you PCM.
A.J.
Old Jun 27, 2012 | 06:43 PM
Danton88's Avatar
Danton88
I hooked up a temporary positive lead and a temporary jumper to #3 pcm output pin still issues, looks like mopar pcm will be ordered soon will post my findings
