trailing wiring question
Old Jun 30, 2012 | 07:57 PM
93MissDakota's Avatar
93MissDakota
Default trailing wiring question
so im gonna hook up a 4 pin trailer light, which wire is what on the four that im comin off of, i got those little clip things that are sweet but i just dont know which one is brake and which one is turn,ect. thanks
Old Jun 30, 2012 | 10:02 PM
VINCE 91's Avatar
VINCE 91
On the 4 way flat plug, the color code is..
Yellow - Left turn and brake light.
Green - Right turn and brake light.
Brown - Tail lights.
White - Ground.
Old Jun 30, 2012 | 11:01 PM
Shelbyfan's Avatar
Shelbyfan
Those quick crimp are junk. Take your time and solder heat shrink the connections. I just replaced mine and someone had used basic butt connectors and I had to remove and require a lot of corroded wiring.
The lighting is brighter than it ever was, when it worked, sporadically.
Old Jun 30, 2012 | 11:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
+1 to that. Especially the outside wiring gets corroded right away.
Old Jul 2, 2012 | 06:57 PM
93MissDakota
alright good to know thanks
Old Jul 2, 2012 | 07:46 PM
JR318's Avatar
JR318
If you dont have a soldering gun they do sell butt connectors that have heatshrink made onto the connector and also has glue inside of it to seal out any moisture. But be careful not to puncture the plastic on the connector where you crimp it or you will get moisture in it there. Soldering is the best way but those connectors are the second best if you cant solder or dont have the proper tools.
Old Jul 2, 2012 | 07:52 PM
volaredon's Avatar
volaredon
buy a kit that plugs into the harness directly and the tail light plugs piggyback into. easiest trailer wiring job ever and whoever invented "Scotchloks" should be hung by their private parts....
