adjusting transmission bands
Old Jul 30, 2012 | 12:01 AM
danherrewig@gmail.com's Avatar
Default adjusting transmission bands
I have a 1995 Dodge Dakota, the transmission is slipping going from first to second gear. My question is the Chilton's manual instructions for adjusting the bands states:
Front (Kickdown) Band
The kickdown band adjusting screw is located on the left-hand side of the transmission case near the throttle lever shaft.
  1. Loosen the locknut and back it off about five turns. Be sure that the adjusting screw turns free
    1. Tighten the adjusting screw to 72 inch lbs. (8 Nm).
    2. Back off the adjusting screw to 21/2 turns.
    3. Hold the adjuster screw in position and tighten the locknut to 30 ft. lbs. (41 Nm).
    ly in the case.
I'm confused about #2 & #3 instructions. Or maybe I'm over thinking it. Will this tighten the bands enough for second gear to function correctly? And if not, is it possible to adjust more? Wha twould one's suggestion to try next.
I have changed the fluid, the filter and also added Lucas transmission treatment.
Old Jul 31, 2012 | 02:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
On step 1 you tighten it to the spec.
On step 2 you loosen the bolt 2.5 turns.
On step 3 you hold the bolt still and tighten the lock nut.
I will move this to the 1st generation Dakota sub-forum.
Old Jul 31, 2012 | 06:00 PM
dobaroy's Avatar
dobaroy
If you do exactly as Crazy says it should work . . . good luck with it.
Old Jul 31, 2012 | 06:05 PM
kahanabob's Avatar
kahanabob
on my 90, old tired tranny, i did steps 1&2 then tightened 1/4 turn, just because. like i said, old and tired. result was a nice solid shift.......
Old Jul 31, 2012 | 07:54 PM
JR318's Avatar
JR318
If it still slips its shot.
Old Aug 9, 2012 | 05:57 PM
wyrmrider's Avatar
wyrmrider
There is a more accurate way by rotating the driveshaft while tightening the band then backing off
Ask Transgo about iit
you did use atf+4 - right?
If your band is glazed or worn out...
