Control arm bushings?
Old Aug 3, 2012 | 04:15 AM
torquefiendx86's Avatar
torquefiendx86
Default Control arm bushings?
I am going through the front end of my 95 Dakota 4x4 5.2 with the 4" trailmaster lift kit (I believe) and am wondering if anyone knows if upper and lower control arm bushings are available? or of any that would work? I think the factory ones are a little different in size. Tried a set from napa and ruind them. Ball joints, tierod ends, pitman arm and idler arm are all correct replacemnts..
Any info would greatly help! even if its "Convert it to a straight axle allready!"
Thanks
Old Aug 3, 2012 | 11:50 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I would suggest contacting Trailmaster and see if you can order replacement bushings. Next is to go to this site it has the part numbers for the lift kit but you have to see if Trailmaster has the replacements. http://www.walt-n-ingrid.com/modific...tml#Suspension Lift
Old Aug 5, 2012 | 02:45 PM
96Kooter's Avatar
96Kooter
If you haven't found 'em already, I think this is what you're wantin' http://www.autopartswarehouse.com/se...ue=Trailmaster
Old Jan 13, 2016 | 10:59 PM
dakota4x4boy's Avatar
dakota4x4boy
Hey I was looking through dakota posts and saw yours. I'm looking for the same thing you were a few years ago. I need new upper control arm bushings for the trailmaster lift kit on my 93 dakota sport. Did you ever find the right replacements? Or figure out what to use? Any info would be appreciated.
Thanks
Dan
Thanks
