EGR question?....
Old Aug 13, 2012 | 09:24 PM
dblackmanc's Avatar
dblackmanc
Default EGR question?....
"95 3.9 V6 5 spd. 214,000 miles
Truck cranks and runs great...but I'm getting a check engine light after driving for 15 minutes without stopping. It never comes comes on any sooner but stays on until I turn motor off and then it will go another 15 minutes. I checked the codes with key switch and got a code 12 and a code 32. 32 is EGR problem? Truck has no sign of an problems driving it. So how do I test my EGR ? and what can I expect to gain as it is driving just fine? I get about 17.5 mpg around town and about 23.5 on the road.
Thanks for your help,
Dan
Old Aug 13, 2012 | 09:43 PM
Soundguy's Avatar
Soundguy
I changed mine on my 94 V6 auto w/ 153,000.
I started getting the 32 code right after I cut my rattling cat off. The CEL would come and go at random...always showing the 32 code when I checked it. The truck ran great all during this so, I didn't worry much about it for a few more months.
A couple of months ago I replaced the EGR....no more CEL or 32 code. Couldn't tell much difference in performance or MPG but, it did seem a little smoother but, that could be my imagination. It seems every little thing I do makes it a little better.
The old EGR didn't 'look' that bad, a bit of carbon but, the pintle seemed to move freely enough. It could've been a problem with the gizmo attached to it. All I know....it runs great now and I don't see the CEL anymore.
Old Aug 13, 2012 | 09:57 PM
volaredon's Avatar
volaredon
if it aint running bad from the "bad" EGR I would probably black tape the lite on the dash if you arent in an emission required area and run it into the ground
Old Aug 14, 2012 | 01:30 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Usually what fails is the EGR vacuum modulator that sends vacuum to the EGR to open. To isolate the problem you need to do a few things.
1) Get a hand held vacuum pump and put in on the EGR nipple. The one ON the EGR, don't put in on the black EGR vacuum modulator. With the engine running pump it up. If the engine dies, the EGR valve itself is okay. If it doesn't, now you have to determine if it's a plugged passage or a bad valve.
2) Get a vacuum gauge. Hook it up between the EGR valve and the EGR vacuum modulator. Take it for a road test. Watch the gauge. Under light acceleration and cruise you'll pull less than than 5" of vacuum. If it does than you have a problem somewhere else.
A.J.
