Wheel won't come off
Old Aug 21, 2012 | 08:29 PM
96dakotaaz's Avatar
96dakotaaz
Default Wheel won't come off
I am replacing my front right tire on a 96 dakota, took the lugnuts off and the wheel just won't come off...is there a trick to this? Is there something else that needs to come off so the wheel can come off too?
Old Aug 21, 2012 | 09:36 PM
adrenalinejunki's Avatar
adrenalinejunki
put one lug nut on a couple of threads and hit the tire, "not the rim" with a sledge from under the truck or do what i do and sit on ur *** and rotate kicking the tire on the left and right side. it will eventually come off but becareful not to kick it off the jack....
Old Aug 23, 2012 | 10:53 PM
marcar1993's Avatar
marcar1993
^What he said.
Old Aug 24, 2012 | 11:08 AM
96dakotaaz's Avatar
96dakotaaz
adrenalinejunki: That is exactly what I did, and it did come off after I read your post. A bit unnerving to see the truck rocking and I am partially under it...I did have the jack in place, and for good measure I also had a jackstand as a back up. Thanks for the tip, I'd never changed a tire in my entire life that required kicking the s*** out of it!
Old Aug 24, 2012 | 01:56 PM
NeosKota's Avatar
NeosKota
If you have aluminum rims, a little bit of never seize around the centering hub helps alot, its cuased by the differences in metal "aluminum on steel" i think its called galvanic corrosion, not sure on that though. My truck has sat for 2 years, when i went to redo the back brakes, mine were really stuck on, i used some PB blaster, let it soak a day, then proceeded to kick the hell out of them.
Old Aug 25, 2012 | 11:41 AM
adrenalinejunki
no problem, i worked for discount tire and on many occasions i had to hit the tire with a sledge hammer to get them off but the cars were on a lift so i didnt have to worry about it falling but its always better to be safe than sorry when doing things like that so it was a good idea to put a jackstand in place.. befor reinstalling the wheen you can buff the hub and back of the wheel to remove any rust or corrosion
