erratic idle
Old Sep 1, 2012 | 12:49 PM
95slt's Avatar
95slt
Default erratic idle
made quite a few changes to my dakota lately..new tb, mopar ecu, headers, new wires,plugs, wires, coil, modified beer barrel intake..etc. was having problems getting it to start but figured that out but now it has an erratic idle.. and eventually dies. any pointers on what to check first? i am guessing a vacuum leak somewhere..
Old Sep 2, 2012 | 08:06 AM
JR318's Avatar
JR318
Try running some seafoam through the gas and also through the oil. Check your IAC valve and make sure its cleaned. Does it do it when its cold or warm? Or both? Since all the changes also try resetting the pcm and the drive it and let it relearn everything.
Old Sep 2, 2012 | 08:21 AM
cornchewincowboy's Avatar
cornchewincowboy
Have you cleaned the throttle body?
cornchewincowboy
I now read you did, so sorry.
Old Sep 2, 2012 | 09:48 AM
Crazy4x4RT's Avatar
Crazy4x4RT
My guess vacuum leak too, a bad EGR may fall in that category.
Old Sep 2, 2012 | 10:21 AM
95slt's Avatar
95slt
egr was eliminated as part of my recent mods
cold start ( haven't driven since doing everything)
ripped off intake manifold ( going to try resealing it)
going to either clean or replace the iac - mine is pretty dirty ( though didn't do it before I did everything)
installing a screaming demon coil ( they recommend 0.65 spark plug gap but my experience doing that with the ranger- runs like crap so gapped them at 0.45)
