Box bolts
Old Sep 27, 2012 | 02:20 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You don't need heat and you don't have to worry about snapping off the weld on the nuts. If you need a picture of the bolt assembly here is a picture. The large black body lift spacer may not be on your truck though.
Old Sep 27, 2012 | 09:46 AM
Hansm14's Avatar
Hansm14
One final question-How do you know if the bed is loose and needs tightening? My wife thinks so.Says it rattles to much.
Old Sep 28, 2012 | 09:22 PM
RockGuardedDak's Avatar
RockGuardedDak
I just say to use heat because my box bolts don't look that new. I live in a city where we put more sand on the street in the winter than we do concrete in the summer :P
Old Oct 23, 2012 | 06:08 PM
Hansm14's Avatar
Hansm14
Thanks guys.I think I know enough now,when I get ready to mess with it. I'm not really sure if I need to tighten them or not.Guess it wouldn't hurt.May wait till spring now.Can only work outside.
Old Oct 23, 2012 | 09:32 PM
inuchan187's Avatar
inuchan187
Try putting 100 or so pounds into each corner of the bed. If the rattle is still there, then the bed isnt loose
Old Oct 25, 2012 | 01:35 AM
Dragon159's Avatar
Dragon159
Double check the spare tire if it is still under the box .... mine was loose and drove me a little crazier until I found it.
