Chatter at 45mph need ideas
Old Sep 28, 2012 | 09:53 PM
botrod's Avatar
botrod
Default Chatter at 45mph need ideas
Truck has a weird chatter at 45mph. I don't hear it at lower speeds or if it accelerate it usually goes away. I noticed it might still be there when I accelerate bust not as loud. It sounds like it gets faster. I also can't tell if its in the tranny or motor for sure.
Originally I thought it was a pulley on the motor but I would think it would make noise all the time.
Is this possibly lifter chatter I can resolve by adding some marvel oil? Looking for any thoughts or if others have the same issue?
5.2 auto
Old Sep 28, 2012 | 10:46 PM
inuchan187's Avatar
inuchan187
Would you be able to record a video of it and post it on youtube? It will be a lot easier for someone to figure out if we know exactly what the chatter sounds like. Try holding the truck at the same rpms in a different gear for a few minutes. If it doesnt make the noise, it probably isnt the motor.
Old Sep 29, 2012 | 01:22 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
It might be your lock-up torque converter, It comes on around 40-45 mph. You're probably right at that point where it applied and releases. Mine does the same type of thing. I haven't had a chance to drive with my scan tool on it to see if that's what it is.
A.J.
Old Sep 29, 2012 | 08:40 AM
botrod's Avatar
botrod
I will try to record it today. Thanks for the ideas guys. I need to take the truck on a long trip and was just worried it could be something bad.
Old Oct 12, 2012 | 09:32 PM
botrod's Avatar
botrod
Tried recording the sound but the exhaust drowns it out. I've noticed it getting worse so took a friend of mine for a ride and he thinks its valve noise. He mentioned he had a similar issue in an old truck and it got worse when the oil needed changed. My oil is over due for change and I'm hoping that helps. I bought some of that engine "restorer" and will add it with the oil when I change it.
Sound logical or familiar?
