Oil pressure sensor problems
Old Oct 7, 2012 | 06:01 AM
Spire's Avatar
Spire
Default Oil pressure sensor problems
I need help trying to figure this one out. I drive a 4 cyl., 96' Dakota. I had an oil leak from the oil pressure sensor itself. Today I went to o'reillys and got a new one. When I got home it turned out the one I got from them was the wrong one. the nipple of the sensor that screws into the elbow on the side of the block was larger than the sensor I pulled off. I went back and they said it was the right one. so after looking at differrent sensors the only one that would fit goes to a 97' Dodge Daakota. I put it on, but the oil pressure gauge isn't showing the pressure now. any ideas?
Old Oct 7, 2012 | 07:31 PM
volaredon's Avatar
volaredon
"I put it on but the oil pressure gauge is showing the pressure now"
sounds like its working as designed
Old Oct 8, 2012 | 08:57 PM
Spire's Avatar
Spire
Sorry, i meant to say that the oil pressure gauge isn't working now. Is it possible that there are two different size nipples for the 96' 4 cyl., but oreilly's is only carrying the larger diameter sensor?
