Need Help
Old Nov 7, 2012 | 07:20 PM
dirtydan2727's Avatar
dirtydan2727
Exclamation Need Help
i have a 93 dakota 4x4 3.9 i recently bought it ran fine up until a few days ago i thought i ran it outta gas cuz it was spitting n sputtering when giving it gas in gear i put gas in n did the same thing so i did a complete tune up took it for a ride n did the same i then changed fuel filter thinking it got clogged wit dirt it ran the same until it finally cleared up a hour into driving it the next day i went to get gas it ran fine there shut it off started right back up went to head home my junk in the bed was rolling all around stop at a store tighed it down left the truck running when got back into truck put it in reverse n it stalled out put it back in park tried refiring it wouldnt start cranked over didnt seem to get any fuel opened hood released pressure from valve tried starting again took a few cranks started up n idealed fine put it in drive n wanted to stall gave it gas n seemed fine got to my street took the corner n it died tried releasing pressure again n did nothing had to hold gas to floor to get it to start put it in reverse or drive n stalls out..got it to my house so far im put a new fuel pump the fuel filter a new ideal air control vaulve whole throttle body from bone yard checked all vaccum lines can see n does the same thing u gonaa hold the pedal to the floor to get it to start n have to race it n mess around to have it ideal but once u give it gas it dies or put it in reverse or drive stalls out n dies..I am in serious need of help im a mopar fan n bought the truck to save it from the scrap yard but its got me puzzled n am just ready to give up n send it on its way so anyones help would be very much appreicated if u think u kno what would do this thank you
Old Nov 7, 2012 | 07:45 PM
Dakotaboy87's Avatar
Dakotaboy87
First off, does it show any codes? Secondly, try the IAC, this located on the throttle body. Clean it or replace it if needed, if that's the prob, it should clear alot of the troubles up.
Old Nov 7, 2012 | 08:00 PM
Dakotaboy87
Also check and see if the notorious splice is bad.
Old Nov 7, 2012 | 08:47 PM
dirtydan2727
I replaced the IAC wit no difference n to my knowledge there r no codes no check engine light
Old Nov 8, 2012 | 02:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Not all codes will trip the Check Engine Light. There is an easy way to check them. Check the FAQ in this section for a how to and a list of the codes. Also did you check to see if your getting correct fuel pressure? Did you change the fuel pressure regulator?
